Manual for old craftsman?
Bensawsome
Hello,
I was just given an old Craftsman Eager 1 model number 131.908020 lawnmower by someone and I want to get it going but I would like the manual so I can make sure I'm doing some of this stuff right. I tried googling the model number but was unable to find a manual or even maintenance info or a video about it. Anyone know where I can get a manual or any resources about getting it going again? The main things I need is the fuel type, oil type, and the spark plug type and gap. I put a photo of the mower below in case that helps at all.
Thank you.
EDIT: I just saw the link to repair manuals on sears parts direct and while it found the model number there was no owners manual unfortunately.
Bellcrank
Greetings. Not sure on the mower manual. Looks like a Tecumseh engine. Think'n tecumseh model number should be located on engine shroud above spark plug. First 3 digits 143. xxxxxxx. Plug RJ19LM, .030 gap. 30w oil in the summer. Make sure cool'n fins are mouse nest free. Not sure on the air filter.
Telesis
You can locate the treasure-trove of Tecumseh manuals here:
May I suggest you specifically look at 1) Basic Service and Troubleshooting information, 2) 3-11 hp L-head manual(this is the Technician's Handbook), and if you 'veg' out on carburetor stuff, then 3) Carburetor Identification, Troubleshooting and Service Manual
#1 above should suffice for what you need. Hope this helps!
Good luck!
