Main drive belt Murray 8 30
Mac 624
Hi,
I recently have bought an old Murray ride on Mower, Type 8/30. The main drive belt is too strong, so it is impossible to disconnect the tranny from the driveline properly. Does anyone know the size of the drive belt?
1/4" x 40,5" ? Is that right?? I have attached a pic, hopefully it works.
Thanks
Bernhard
If you post the model number I think I can get you some part numbers.
Mac 624
Thanks for the offer, but there is not a dealer around here for the Murray. I have to go to a industrial supplier, where I can get a belt for half the price they ask for it at a small engines repair shop. But therefore I need the size.
If I can find a part number I can cross reference that number and tell you what size belt you will need to order. I know a 1/4" belt is not right.
Carscw
I think it will be part # 37x110 Size will be 1/2x43-7/8 So you can go with a 43 or a 44
Sent from my iPhone using LMF
Mac 624
Ok...I have the mower stored out, so no modelnr. at the moment. But I will got there and write it down. What means 37 x 110 ? I have some probs by converting inch into cm, but it canエt be 37 " to 110 ".
Never understood Murry's numbering system. Do know that Gates belts do work well on Murrays. Go to an auto supply store and have then cross that number.
Mac 624
Prob is, that they only have metric belts. 1"= 25,4 mm and if the belt would be 1", 26 mm will not fit.
I'll cross the belt to a metric size tomorrow at work and post back tomorrow night if I can remember to do so. Sorry I didn't see you were from Germany.
