My brother got a magnum 20 about 2 years ago, and now I'm the owner of it. It has a good amount of issues.
The bore is a mess and full of rust.
The governor gear and oil pump gear are destroyed and damaged respectively.
The crank has a ton of raised edges on cylinder 1.
The rod snapped from being defective.
It's missing the governor arm, the gear, and the carb.
The block is fine, surprisingly, and the crank bearings and the crank for piston 2 are fine.
The halves of the block
The chunks of rod left over in the bottom of the crankcase.
The side that threw the rod. The cylinder jug has a good bit of rust in it.
The side that had the good piston. The cylinder jug has rust on the bottom edge.
The remaining piston head. My brother took it out and lost the wrist pin. The rod is there just not pictured.
