M60 tank
fitch580
I own a 2006 cub cadet commercial M60 tank .When I got it out for the first time this year I noticed that the paddles are stiff and very hard to push. I gave it a good cleaning but that didn't help anybody got any ideas
fitch580
O.K. the sticks
Luffydog
Right where the sticks paddles go down into frame under the seat there is a spring most have grease fittings there or just spray some good ole wd40 in there and work them they should loosen up.
Darryl G
What about the dampers? Can they get tight? I've only had mine go soft, but suppose it's possible.
Luffydog
Guess they could but I haven't seen them do that.
fitch580
I found 2 hidden grease fittings on the shaft that the drive levers hook too so I gave them some grease and that seems to have fixed the problem.Thanks for all of your replys and comments
