M-ZT 61 wont start after running
Tomaszewski84
Hey everyone,
I have a husqvarna mzt 61 with a 23hp kawasaki power plant zero turn. I can currently start it right up with no issue when first starting. Once I've ran it for awhile it will turnover but not start. I start it by touching the contacts on the solenoid and it fires right up. Once I've ran it for over an hour it won't even turnover, again it fires right up when I contact the solenoid. Any ideas?
Check the oil level
If it gets too low the engine will not crank
When cold all the oil is sitting in the sump
Afte running a fw minutes anout 1/4 of that is everywhere else in the engine so the sump level drops.
Tomaszewski84
Thanks for the response, will check and get back.
