LX460 PYO Belt Problem
g9stuart
Good Day to all.
I have an LX460 that just loves to shred belts. I have gone thru 1 OEM belt in a matter of hours. Bought a new belt engage cable and a green power belt it lasted maybe 2 days, Bought a new power belt checked all the pulleys and spindle assemblies, No problems found. I do think the deck has been worked on as I found a spacer under one of the idler pullies. I did notice one of the pullies was low and belt was running at the top of the pulley. This belt lasted all of 2 hours. Any suggestions? Does anyone have the specs for pulley height and alignment for the PTO belt?
Thank You all or your help.
Greg
Auto Doc's
Need the product label information off of the machine. Too many possibilities to guess.
g9stuart
Thank You for your reply,
Here are the numbers that I have:
Model --13AX60RH744
If this does not help, please guide me as to where to look for any other numbers.
Thank You
Auto Doc's
Which pulley has a washer under to change the height of the pulley? That could be a factor, or wrong pulley was installed.
Here is a diagram of the deck components for that model number:
Hammermechanicman
Is the belt actually shredded? If so it is rubbing something it shouldn't. Is it melting and smell burnt rubber? If so idleror spindle is binding and sropping or belt rubbing someting it shouldn't. One edge of belt chewed up? Idler out of alignment from bad bearings or worn arm pivots.
