Doityourself
- May 23, 2017
- 1
I have a LX178 JD that will start right up but after 5 or 10 minutes it just shuts down. Wait 15 minutes and it will start up, but will shut down after getting hot. Radiator is full, fuel pump checked, filters changed, checked the pressure hole in the gas tank to make sure it is clean. What maybe causing the shut down? I can get it started without the mower on but it still will shut done after a minute or two. Seems that when it gets hot it just shuts down. Could it be the ignition coil, but I have two so it would need to be both coils at the same time. Any answers would help. Thanks
