lx176 has no spark
swinks
first I changed out the coil still no spark, tested the new coil with an ohm meter its ok. coil is gaped correctly, the magnet holds a common sized screwdriver up no problem, unhooked the ground wire on the coil and still no spark
reynoldston
Kawasaki FC420V That engine not only has a coil but it also has a timeing module. I think you will find it on the ignition switch if not its on the side of the engine block.
