Hey everyone,
I figured someone can help before I continue to throw parts at the mower. It would not start. So I tested the solenoid and have power at the yellow wire when I turn the key. I ordered a factory solenoid and replaced it. (Could jump the posts to get it to turn over) However, either I got a bad solenoid out of the bag or another problem. I assume it can be the key tumbler (though I get a test light when I turn the key at the solenoid) The brake switch, seat switch and or PTO switch. Before I start buying part after part was wondering if someone has a way of finding which is the bad component? Any advice in trouble shooting this would be appreciated. Thinking maybe I should bypass the seat and brake switch? Thanks in advance,
Chris
Chris
