Export thread
LT1042 Engine Turns On But Doesn't Move/Do anything else
#1
W
walczyk
Where should I look for first? Electrical troubleshooting guides on google are scarce.
edit: well the drive belt fell off the pulley on the engine, so there was no way it could do anything. The belt had a lot of slack, then I saw the problem. The belt was chewed into by the pulley and up above the belt protector things. There's no way to get it off and on without removing the pulley or lifting out the engine. I have no idea how I did that when I replaced the clutch. I'll have to rent/buy a pulley removal tool kit I think
