Lt1000 ignition key dupe
crazy charlie
i am about to buy a key on ebay and was wondering if anyone knows if these come precut?? or in a blank that needs to be cut?? They look precut to me but I cant get a reply from seller.Anyone?? anyone?? thanks Charlie
BlazNT
All keys are the same so no cutting required.
With the exception of John Deere there are 6 precut keys on my work keyring.
To date one of them has fitted every mower I have come across since I started.
All the key does is allows you to stop you 10 year old from drag racing your mower around the yard when you are not home.
JD fit their won locks to their commercial range which use the same keys as the road side plant ( tractors, graders etc ) and there is 27 of them from what I have been told.
