lowes tiller
jd335
hey everyone i was servicing my lowes rear tine tiller and discovered i had a busted rim i have looked every where and cannot find one lowes tells me they no longer have a parts listing for them it's a 5hp the tire size is 13x5-6 does anyone know of a online store where i can find one thanks
jd335
the model number is 95220.
Muhammad
Administrator
Staff member
That tiller is made by MTD. Part number for the wheel is MTD 734-1377 for the left wheel and MTD 734-1378 for the right wheel. Unfortunately in searching online it seems it's been discontinued and no longer available. Not sure if they've replaced it with a similar part or not. Looks like the list price on the part was around $75 when it was available (including tire).
How is it broken?
jd335
it's broken beyond repair i could have welded it but not now thanks for the numbers i might can do something with that.
KennyV
If you don't find it...
Try to come up with the rim description...
It's a 6 inch rim, what is the hub and offset...
is it a bolt on rim or keyed?
I have several sources for wheels if you can give dimensions and descriptions... :smile:KennyV
Muhammad
Administrator
Staff member
Here's a parts diagram. If the tire is a 13x5-6, you should be able to find a rim with a center hole that will work. I can't see from the diagram if the center hole is threaded or not or if that would even matter. Looks like so long as there aren't any clearance issues, something like this might work:
13x5-6 ATV Quad Go kart Front Rear Tires Wheel Rim - eBay (item 150447731254 end time Mar-20-11 16:45:26 PDT)
FRONT Mini ATV Quad 49 50cc Wheel Rim 6" 13X5-6 NEW - eBay (item 150448553994 end time Mar-22-11 18:29:38 PDT)
JDgreen
Muhammad is right, visit Ebay and you can usually find just about anything. I just logged out of there, purchased a set of JD brand Gator mulching blades, the JD dealer wants $90 and 6% sales tax for what I purchased on Ebay for $49, no tax, free delivery, no burning $8 worth of gas to get to the dealership and back...:thumbsup::smile:
jd335
thanks for the ifo guys the atv wheels have a bigger center hole mine is three quarter inch but i can build it up then turn it down but i have a little time here so i'll keep looking oh yea the wheel just slides on axle and pen goes threw wheel and axle with cotter key in pen.
KennyV
This is the wheel & tire description that I think you will be looking for...
it is a stock wheel type and should be available locally ...
13 x 5.00-6 NHS
Pneumatic Drive Wheel Assembly - White Carlisle X-Trac, 2-Ply Tubeless, 1/4" Pin Hole
Metal - Offset Hub: 7/8" Dia. x 5-1/8", WT. 8 LBS.
OR this one...
13 x 4.00-6 NHS
Carlisle XTRAC - Gray
2-Ply Tubeless, Hole for Pinning, Metal - Offset Hub: 3/4" I.D. x 4-5/8", Max 22 psi, WT. 9 LBS.
Measure the length of the mounting tube in the center... it could either be 5 1/8 or 4 5/8 ... KennyV
