I have bought a Toro Super Bagger for this season. I am very happy with everything about it, except for some lawns I cant get the cut low enough. I could really do with another approx 5mm-6mm (half inch) drop.
At the risk of ridicule, being called an idiot or worse (tin hat on :smile
.... can i use 3 to 4 washers behind the blade to lower slightly?. There is plenty of thread on the bolt and I torque as per manual (i realise it will also affect the highest setting and I am ok with that as I never use on high)
