Need intake&exhaust valve clearances for Briggs model number 402707
R Rturner Forum Newbie Joined Jul 21, 2018 Threads 2 Messages 2 Jul 21, 2018 / Low compression #1 Need intake&exhaust valve clearances for Briggs model number 402707
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Threads 65 Messages 24,995 Jul 21, 2018 / Low compression #2 Rturner said: Need intake&exhaust valve clearances for Briggs model number 402707 Click to expand... Answered in the small Engine section.
T Tinkerer200 Well-Known Member Joined Mar 14, 2015 Threads 4 Messages 913 Jul 21, 2018 / Low compression #3 Rturner said: Need intake&exhaust valve clearances for Briggs model number 402707 Click to expand... I can send you a Service Manual for your engine IF you like, address below, put in proper format and remind me model number and what you want. Walt Conner wconner5 at frontier dot com
T The Specialist Member Joined Jul 22, 2018 Threads 5 Messages 48 Jul 22, 2018 / Low compression #4 Rturner said: Need intake&exhaust valve clearances for Briggs model number 402707 Click to expand... Intake valve is .006 and the exhaust is .009 of an inch. You should remove the valves and clean them up!! You will have to do this in order to set the gap anyway!!
