Thanks for the replies. Going to go to the skag dealer and check some of them out, I may hit up the gravely dealer as well. Those are about the only options I have for local dealers. Right now I think I have it narrowed down to the clipper or the hustler. Just need to decide if the added features of the clipper are worth the extra coin. Does anyone know how the Kohler kt 745 stacks up against the kawasaki. It is rated for 26 hp and is 100 bucks less on the clipper. My dixon has a kohler command and it has been great. My understanding is that the kawasaki is an 800 hour motor if maintained properly. My dixon has that and then some and is still ticking away. Thanks again for the help.
I really don't know where you get this 800 hour motor if maintained properly thing from?
If you are going to test out the Hustler raptor sd, make sure that you test the sd60. I was originally going to buy the sd54 but the 60 comes with an engine guard and I thought the seat felt much more comfortable. If comfort on bumpy terrain is a concern just don't want you to sit on the cheaper seat and have a bad impression.
If they only last 800 hours I better go buy a new one today. Fr651 1300 hours. Guess I got one that was not inspected.
I was digging around one of the other lawn care forums that is geared more towards professionals. Most of what I read over there said these "residential" grade mowers were made to last 800 to 1000 hours. They all claimed that if you stepped up to the commercial mowers, the engines would last 4000 hrs or more. Seemed logical to me. My kohler is sitting at about 1100 hrs and starting to used a bit of oil, smokes on start up. Also I read it on the internet so it must be true. Maybe its just a way for guys to justify spend 10k on a mower. I know that I put 60-70 hrs on my mower in a season, 800 hours would last me 12 years or so. I also know that I cannot justify spending over 6k on a mower.
