Hello! I've had a contractor cut my lawn the past two years and now I'd like to start doing it myself. There is approximately .75 acre of cutting area. It is mostly flat with a very slight slope away from the house in all directions. There is a fence around a portion of the yard and a couple trees. Otherwise, it's pretty open space. There are portions of the back yard that get pretty wet and with all the rain we've had this year, stays wet for quite some time. I originally started looking at tractors, but then worked my way over to zero turns for the increased maneuverability and speed. While I'm sure a zero turn with the EZT transmissions would work fine on my property, I'd like to go a step-up in that area for increased longevity. I'm open for the discussion if members believe I can get 10+ years out of the EZT transmission models. However, I'm thinking ZT-2800 or ZT-3100 for something that will last at least 10 years or more. I have a few local dealers that sell various brands including Cub Cadet, Ferris, Scag, Bad Boy, Toro, and Gravely. I haven't looked further away, but I believe there is an eXmark and Hustler dealer farther out.
EZT: Bad Boy MZ-Magnum, Cub Cadet Ultima ZT1, Gravely ZT-X, Toro Timecutter MX
ZT-2800: Cub Cadet Ultima ZT2, Ferris 400S, Gravely ZT-XL, Scag Liberty Z
ZT-3100: Bad Boy ZT-Elite, Gravely ZT-HD, Toro Timecutter HD
Here are some of my thoughts based on internet research and a quick peek at some of them. I'm looking for your feedback on things I may be missing or overlooking since I've never used a zero turn before. If I'm out of line with my assumptions, please let me know there as well.
Bad Boy: Seems to be built very well with a lot of steel, however the 2 year warranty seems very short compared to all others. Electronic deck height - not sure if this is a good thing or not. I have not seen it in person yet. I believe it's in the upper 4's.
Cub Cadet: They are releasing a new line called Ultima. I've seen some YouTube videos and looked at the details on the web site. Seems very impressive. The ZT2 model offers ZT-2800 hydro's and a Kawasaki FR730 for ~$3700. 3 year unlimited hour warranty and lifetime warranty on deck/frame - sounds good. You can select the deck height from a dial on the operator panel. I have not seen it in person because it just came out.
Ferris: The suspension sounds like a great feature, and this unit is about 100 lbs. heavier than the other zero turns in the ZT-2800 class. I assume this is a good thing that provides added stability. I like the 8mph forward ground speed - faster than any other zero turn in the ZT-2800 class. The 4 year warranty is nice. Looks real nice in person. Deck height looks like a pin into a panel with many holes each with a different height - is this good/bad versus the electronic or control from the operator panel? I've seen several others the same way. ~$4300
Gravely: Don't know much about these at all.. Have not seen them in person. From what I've read, provides good value for money spent. I heard the ZT-X does not make for an easy oil change. I heard the HD model is a great bang for the buck, but you're pushing ~$5000-$5200. 3 year warranty and 5 year on deck/frame.
Scag: Comes with a 5 year homeowner warranty, which is the best I've seen. I've heard the cut is really nice on this one. Looks nice in person. ~$4300
Toro: They don't have a ZT-2800 model, unless you go with the MX with a 60" deck, which I believe is too wide for me. The only other option then is the Timecutter HD with the ZT-3100 hydros. I saw it in person and it was very nice. That is close to ~$5000. It did not have the MyRide suspension. The specs seem really nice and it has 8.5mph forward ground speed which is nice. It has the Toro commercial V-twin engine in it. I haven't seen any bad reviews about this engine, but don't know much else about it. It appears you can buy a maintenance kit that will allow you to extend the warranty to 4 years (instead of the standard 3).
When looking at all of these models, I'm somewhere in the upper 3's (Cub Cadet), to low 4's (Ferris, Gravely, Scag), to upper 4's/low 5's (Bad Boy, Toro, Gravely). I'm looking for something that will be reliable, cut well (seeing stripes would be nice) and as fast as possible, easy to maintain, and last me for quite some time.
Thoughts, comments, feedback? Should I be looking at any other brands? Am I missing anything here?
Thanks!
