LGT2645- Wiring
Mozz
Hello all,
I have an LGT2654. We have wiring that is not connected. Trying to see where it goes to.
Anyone have a schematic for this mover?
Attached are pics of the wiring and where it starts to go. I see that it leads to the ignition area.
Any idea about where this goes to? what it does on the mower? And where should it end at?
Post the numbers from under the seat.
And you will find that image as the very front page of your parts manual which is a free download from Husqvarna
Mozz
Here is the information from under the seat!
Mozz
Anyone know what these wires go to?
  • IPL, Husqvarna, edit.pdf
Many times doing electrical diagnosis means falling back on the basics. In this case trying to identify wires will not be a quick job. You are going to have to get out the Ohm meter, look ant the wiring diagram and backtrack them.
Mozz
Since it is only the wires, what do I connect the meter to? I have used them when I see the parts, but here I don't seem to have a starting point.
Mozz
Anyone have a pic of this wiring, and where it goes to? This will help greatly. It starts at the ignition key, comes down the right sight of the seat, and looks like it ran along the right of the engine.
