Hello. I started my Hustler Super Z and attempted to back it out and mow. My right side worked but the left would not go forward or backwards. I checked fluid and it's at the correct level. I then jacked the mower up. Neither side would move by hand with the levers in park. I put the levers in neutral and I could spin the right tire by hand but the left would would only move back and forth maybe a 1/4". It seems like something is wedged preventing movement. It won't move even with the release valve on the pump activated. Any ideas?
