Repairs Leaking seal on axle shaft.
cambre
I have a Craftsman zts7500. One of the hydrostatic transmissions is leaking oil. Looks like it leaked a cup full over nite, I had a time refilling it. Its leaking at the axle seal. This may be a sealed transmission, I don't know. Can the seal be replaced by a novice like me? I was a break & front end mechanic back in the early '60s but things have changed since then. Cambre
Most likely the transaxle is a hydrogear and all you will need to do is remove the wheel hub, and remove and reinstall the seal.
cambre
ILENGINE, Thanks for info. That is what I wanted to hear. Cambre
motoman
cambre, try searching the forum with tag . I think someone went in on a problem like this recently
cambre
Thanks motoman: Went to tags and found good info. Cambre
