Lawnboy Supreme with D engine surges
bwright1818
It runs smooth when not moving or cutting anything. However, if it bogs even a little on heavier grass, it starts to surge and won't come out of it until I just stop and let it sit there. I cleaned the carb, even tried another clean carb. It has good fuel flow from the tank and the vent in the cap is clear. I even tried mowing with the cap a little loose. This is a two stroke, D engine with a metal body, Walbro carb, which has a true choke. No primer. These carbs have a screen in the nipple of the carb, which I removed and put in a new, Briggs type, inline filter. I put a new lower crank seal in. Still surges. It acts a lot like a Duraforce surge, but it has a different cab than that. I have been a hobbyist Lawnboy geek and a marine mechanic professionally, for over 50 years and this one has me stumped!
Fishnuts2
Have you tried turning the "altitude adjusting screw" if it has one on the Left side of the carb?
Tiger Small Engine
Enlarge the pilot jet as a last resort if no air leaks, etc.
