D dubba Member Jun 19, 2012 #1 What are some of the symptoms when a gas cap fails? How can it be tested?
B bwestbrook Well-Known Member Jun 19, 2012 #2 The mower will act as if it is not getting fuel. You can test this by unscrewing the gas cap partially and seeing if the problem persists.
