thehorseshoer
I've got a Snapper 52" Zero-Turn Mower, 26 HP, Twin Stick, RZT 285Z Series, and I use it all the time to mow about 10ish acres.
I believe the PTO Clutch is going (going, goooone). Recently, whenever I hit the switch to engage the blades it started hesitating. Then it would flat out not engage for a few minutes, especially after it ran for a little while. Today, when i hit the switch it didn't engage (as per usual by now) and took a very long time to catch and start turnign the blades. A few minutes later, there was an enormous cloud of blue smoke that smelled like burning paint following me.
I assume that the PTO Clutch is officially toast, yes?
If so, i obviously need to replace it.
This is the website I usually order parts from.
https://www.partstree.com/parts/sna...-turn-mower-26-hp-twin-stick-rzt-285z-series/
Are these the right parts?
https://www.partstree.com/parts/sea...94385dc9fe3d533c9fac4a00c77&searchTerm=clutch
Thanks in advance!
Thanks in advance!
