Lawn Boy motor swap?
I am posting this in hoping that I can get some info on swapping motors on a Deluxe 19 inch lawn boy from about 1975. Is there any motor that can fit on this with not too much difficulties? I tried with a GCV160, but did not work. I searched a lot, but couldn't find much.
F is a good engine , D600 I like better , not so loud, Ebay A man has them rebuilt rcengineservice3 in PA.:rolleyes: D600 uses same muffler plate and muffler. D600 is CD igniton TOO.
Bolt this extended snout D-400 brick top engine on it, you will basically have a model 5020 on a model 5024 deck, that 5020 was the last of the extended snout crankcases. It should bolt right on to your existing muffler plate from the 5269G, if you don't have that muffler plate there are plenty of good used ones on ebay.
http://www.ebay.com/itm/Lawn-Boy-Engine-/322391898049
