Export thread
LA170 Riding Mower Wont Start
#1
H
hosedagain
Good day, having issues with my LA170 to star, twin cylinder Biggs, engine. Replaced the plugs and gas filter. Getting a strong spark, took the gas line off at the carb, getting gas. Compression is 70PSI both cylinder, 200HRS. Can any body telling me if I am missing something? What else can I look at? Was thinking of spraying a very small amount starter fluid into the carb inlet pipe or into the cylinder not sure what it would prove, don't really like doing this but getting desperate. I think I will drain the gas its from last fall with gas stabilizer in it. Spray carb cleaner into the gas inlet?
Thanks for your help...
\Ron
#2
Carscw
Carscw
Good day, having issues with my LA170 to star, twin cylinder Biggs, engine. Replaced the plugs and gas filter. Getting a strong spark, took the gas line off at the carb, getting gas. Compression is 70PSI both cylinder, 200HRS. Can any body telling me if I am missing something? What else can I look at? Was thinking of spraying a very small amount starter fluid into the carb inlet pipe or into the cylinder not sure what it would prove, don't really like doing this but getting desperate. I think I will drain the gas its from last fall with gas stabilizer in it. Spray carb cleaner into the gas inlet? Thanks for your help... \Ron
Spray carb cleaner into the carb if it starts then you know it's a gas problem.
I bet you will need to clean the carb after letting the gas sit in it for months.
#3
H
hosedagain
Just had a thought, it might be the safety switch under the seat, will look to see if a wire came loose
#4
Carscw
Carscw
If you have spark and it spins over it will most likely not be a safety switch.
#5
H
hosedagain
you are right it was the safety switch,
Thanks
#6
M
Mikel1
It was the safety switch or wasn't?
