mmahoney626
- Aug 25, 2015
- 4
- 12
The original drag links were replaced at some point in the past with aftermarket adjustable ones. The ball joints are worn on the steering drag link. Does anyone know if a replacement ball joint is a particular (standard) size for this model? Has anyone replaced the ball joint on an adjustable (aftermarket) drag link and what did you use?
The seller of the drag links I purchased does not offer the ball joints as an item that can be purchased by themselves. I went searching for replacement ball joints when I saw that there are different sizes, and my search for replacement ball joints for a John Deere LA145 only produced the entire drag link with ball joint included as the result.
I'd like to only replace the worn ball joint to get my mower back in service.
