LA 135 special edition gas tank bad
ssmith
Gas cap went bad (vent not working) and tank expanded with bottom going into transmission fan which cut tank. Replacement tank from dealer is not a fit in this model. Pt no GY2876 is very loose in the compartment and the plastic fitting is hitting the metal frame that the seat bolts to (rear right corner). Also the gas level window does not fit the opening in the fender deck (tank is to low in the back sloping away from the top of the opening. Is there a tank kit for this model that will fit and last???
