LA 135 22hp Briggs hard to start
cometdiner
I have changed the plug, done the 50 hr service. It still hard to start. It does start eventually. Anyone have any suggestions.... I am at my wit's end. Thanks, Ben
I don't know the answer, but you might want to look at some other threads until someone answers because there are a lot of threads about hard-starting engines. Just look at the bottom of the page at SIMILAR THREADS or search for your problem.
I wish you the best! :smile:
-lmf
Make sure that the choke is closing all the way. If it doesn't close fully it can make engines hard to start, if not impossible.
cometdiner
Thanks I will check it first, then to the electrical side. Thanks
cometdiner
