Export thread
L130 Deck Stopped Working
#1
D
doncarde
While mowing, the blades stopped working. I looked underneath at the clutch and found, what looks like, a broken ground wire hanging near the right front side on the mower. I have no idea where this wire would attach. I think that this may be the cause of the clutch no working. Any help would be greatly appreciated. Thanks.
#2
S
shiftsuper175607
If you don't know where it goes to....why did you call it a ground wire?
A ground wire goes to the frame....it may not be a ground wire but a wire that has voltage at times.
Do not hook it up until you are sure what it is and where it goes.
Does the loose wire have a connector?
Does the clutch have a wire/wires attached to it?
Trace back to where it comes from.
#3
D
doncarde
You are right. I'm not sure it is a ground. It is black. The end looks broken off (no connector). The two wires going to the clutch are good. Will look at it again and trace it back. Thanks.
#4
Glyn Robinson
Glyn Robinson
thanks for your question. let us know what you find.
