L120 - How do I Reassemble the Parking Brake Rod to Bracket and Affix to Frame?
kailor
  • / L120 - How do I Reassemble the Parking Brake Rod to Bracket and Affix to Frame?
Hello all. I'm really at my wits end. I'm trying to reassemble the parking brake rod and bracket to the frame of my JD L120. The one picture I have of the parking brake rod and bracket to frame is not clear as all these parts are covered in sludge and I can't tell what's going on in the picture. I would be very grateful if someone could post a couple of pics for this assembly. This is all due to having to replace the gas tank. Once I hurdle this issue, I'm home free. Thanks in advance!
Keith
Boobala
Keith
I have a JD 120 MANUAL but it's in PDF form can't post it in a forum, send me your e-mail address in a PM and I will send it that way, then you can download & print what you want or save the entire manual.
1111BRAKES.jpg ........... click to enlarge sample page
kailor
Thanks Boobala. I figured it out but I put the spring washer on nut side of the equation. Will this matter?
