Export thread
L111 won't crank
#1
D
DebHow50
Mower has gas, battery charged, nothing different from previous use. Sounds like it wants to crank but just won't fire off. What else can I look or?
#2
M
mechanic mark
fresh gas, check air & fuel filters for replacement, replace spark plug, change oil & filter if due, always check oil level on dipstick before starting. let us know how it goes, thanks, Mark
fresh gas, fresh air, good spark & compression are needed to run. use JD OEM parts
https://www.green-parts-direct.com/...66JeQ5aGO832Be53DJXENJzn4kWX9hlEaAgPZEALw_wcB
