Kubota ZD326 PTO won't disengage
VFW
The pro on my 2yr old326 zero turn will not disengage after running , seems like throw of lever may be over traveling . Is there a way to adjust linkage ?
Do you have the upgraded PTO Control Handle kit installed? If not you need to get it and install it.
