Export thread
Kubota TG1860 Diesel
#1
J
jdj12cbc
The mower blades slow and stop turning when I get into the slightest heavy grass. However, the engine does not slow or bog down at all. If I disengage the blades and drive further than I can restart them turning again. Is this a PTO clutch failure ($330.00 at my local shop) or a Hydraulic issue from the rear axle that turns the main mower belt?
#2
B
Briggs92
It could just be your belt slipping. Check to see if you have any tears or if its glazed
#3
K
KennyV
Like Briggs92 said...
Check the belt on the deck, you may have a bad idler pulley... :smile:KennyV
#4
SONOFADOCKER
SONOFADOCKER
If the PTO was going you would have blown fuses or hot metal smell . I bet the belts are glazed .
