Kubota G1900S mower does not engage
cpurvis
Anybody familiar with this Kubota tractor and mower?
Only info I've found on it lists it as all-wheel steer, water cooled 3 cyl diesel, hydraulic lift deck (width unknown). Known problem is that the mower does not spin. It is also listed as 'shaft driven' mower.
Does this sound like a minor problem or Big Issue. The current owner bought it in that condition as he doesn't use it for mowing.
Thanks.
Was the shaft removed at some point?
Is there a lever to select rear PTO or mid PTO?
Kubota also uses a lot of safety switches to deactivate the PTO if an operator isn't 'detected' in the seat.
Regards
Jeff
It's all a moot point now. It sold while I was fretting over the shaft drive.
