Kohler XTX675 with Huayi carb - missing pin on arm between throttle and choke control
jpilk99
  • / Kohler XTX675 with Huayi carb - missing pin on arm between throttle and choke control
Hi All,
Machine was running rough and when I dug in under plastic engine cover I noticed a boomerang shaped arm between the throttle and choke control doors was un-connected on the throttle end; (see first pic). A small brass-capped retaining pin was missing; (see arrow pointing to this in second pic). I can't find any reference to the part number for this pin. Can anyone let me know? Thank you.
I believe the Huayi carb part number is 1485390S.
Jay
Not Available order replacement carb.
Kohler 14 853 90-S or Stens 520-055
