ch 22 command ,I converted ignition to mdi .Probably used the wrong coil, but it ran #24 584-45 . It started hard in the winter time,found out I needed to change the flywheel .Kit #24 755 307-s ,comes with coils and flywheel . Backorded unailable . Iwant to get this together . I found a ch23 flywheel with fixed ignition . The flywheel key is in a slightly moved position .The coils on this motor were 24 485-36 ,2 wire but only 1 hooked up . It was apart , didn't see together I have been told to run #24 584 201-s maybe, or 24 485-36 . I don't know . Why do the 24 485-36 coils have 2 wires?
