PTmowerMech
- Apr 16, 2018
- 443
- 3,421
Kohler Pro 20hp CV240S. Spec 65551.
I just replaced the carburetor today. Last year, (when I was even dumber than I am now), I tinkered with the linkage, especially the little screw with the nut on it. (not the governor screw) because it wouldn't rev up very high.
Well, the new carb allows it to rev up way too high.
When I throttle it down, nothing changes, unless I push on the lever where the screw driver is.
It's almost like it's too tight to go back to the left, when I throttle down. After I move it back (to the left) the engine throttles decreases it RPM's like it's supposed to.
Seems like there should be a spring to pull that back. But there's no holes for a spring to attach. So something is messed up somewhere.
Any idea's?
Any idea's?
