Kohler KT-735
Gmom
I have a 2017 Kohler on a Craftsman Pro L Series Zero Turn mower. It began running very rough, then would not stay running. I cleaned the gas tank, changed the fuel filter, and put in new gasoline. It appears no gas is going into the fuel filter. I a. Able to blow on the fuel line to the fuel filter and gas comes out. However when I connect the fuel line, gas does not go into the fuel filter. What is my next step?
Remove the debris from the fuel tank that is blocking the outlet .
