Kohler ID please (no stickers)
PTmowerMech
Seems like I've already already asked about this before. But can't find it in the searches. I'm needing an electric PTO for this. And don't wanna buy the wrong one.
Kohler 183636
m# 13AX11CH712
S# 1C035H20705
Pics:
Scrubcadet10
Moderator
Staff member
According to tractor data.com and me ( I have that engine I think)
It's Kohler courage 19.
I know the model # on my 2010 cub ltx1040 engine starts with sv590-xxxxx
PTmowerMech
Is that enough info to order the right PTO?
The PTO will be specific to the mower, not the engine as it has to fit into the retainer, plug into the electrics and have the right size pulley to spin the blades at the right speed.
SO you look it up using the IPL for the mower and use the 13 number as your refference.
The clutch will probably come up as an MTD part & not a specific Cub part as MTD make Cub.
Use xtremeope clutches when I need one for replacement on a mower. Have had a couple that required some minor mods to make work. So far seem to work Ok, or at least no problems anyway.
