kohler engine
251bamafan
I have had a kohler engine for about 7 years and recently melted the breather seperator kit. Had a new one shipped and I installed it and cut about 2 acres and melted the new one. Was wondering what could happen to cause this.
possibly a hole in the muffler bloweing hot exhaust on the breather melting it. Can't think of anything else that would cause that much heat.
Briana
Hey there - WELCOME to LMF!
I moved your thread to the Small Engine & Mower Repair Forum. :smile:
jameswsr
Where is it melting? Kohler makes many engines, those breathers were used most commonly on CV 11-18. If so it should be mounted right above valve cover a ways above exhaust port. If canister muffler is mounted vertically then thats a possibility. Maybe a pic would be good.
