cswanson49
- May 5, 2018
- 1
- 3
kohler cv22s cranks does not fire. Replaced the following: New ignition moduals, new carb, new gas lines, new spark plugs, new spark plug wires, new gas, new square key, new stater, new fuel pump. Cylinder compression 90. Fuses look good, has spark. Have used starter fluid, nothing. Magnets are secure and look fine. Even tried spraying starter fluid directly on the cylinder. Think that's it, not much left to replace.
