alternative browser.
#1
G
gwilkrrs
I have a LZ25KC604 that will not start, just cranks.
I have added fresh fuel, changed the fuel filter, cleaned the plugs, cleaned the carb
it was running and died going around a corner- I suspected bad fuel as filter looked bad
when turning the key I hear the fuel solenoid click
I took the hose off the fuel pump and verified it is pumping when the motor is cranked.
the motor starts with starting fluid and dies as soon as you stop spraying it
any thoughts?
#2
Scrubcadet10
