Export thread
Kohler 26 HP V Twin Starter problems. Craftsman 54" Cut.
#1
B
Berry
I have a mower to fix from my mother in-law. I order a new starter motor and it will not turn the engine over. Also I notice broken teeth on the engine fly wheel. One section of teeth for about 6 inches is totally gone. The starter engages but will not turn the fly wheel. The old starter has a broken shaft in it. The mower did run okay. I have replaced the battery, plugs, air and gas filters, and changed oil. The motor is not seized. Any suggestions????
#2
Travlitt
Travlitt
Sounds like your starter may have the wrong gear for your flywheel. This would make the ratio wrong and it would either turn part way or break the teeth off of the flywheel.
#3
S
shiftsuper175607
I don't see how you can have broken teeth on a flywheel unless the motor has a catastrophic problem or hydrolock in cylinder.
A lot of force was exerted on the flywheel.
Can you turn the engine by hand with the plugs removed?
