goosemasterkl
- May 2, 2014
- 54
- 121
I have a Cub Cadet LT1050 w/26 hp Kohler Command engine and I'm having issues with the electrical system. The battery won't stay charged up when I mow. The battery is new. I took some measurements today with a digital voltmeter of the regulator/rectifier and the battery. Here are the numbers I got so maybe someone can lead me in the right direction on finding my problem.
1. Tested stator output at the rectifier plug- 47.8 volts ac
2. Tested rectifier/regulator @ dc volts output- 12.7 volts dc
3. Battery test with everything off including engine- 12.85 volts dc
4. Battery test with engine running at full speed- 12.6 volts dc
I can't pinpoint my problem; so any input from someone would be greatly appreciated. Thanks
