KeystoneKid2121 When to change fluids.
johnorlandi
KeystoneKid2121
Reference your March 18, 2023, you asked when to do the first fluid change, I added two charts that were in text format and did not make any since. Since then, I changed them to PDF format and the came out good, so they are attached, and you can use them or make changes to suit your needs. I first made them in MS Excel format that worked great. Hope this helps someone.
  • MAINTENANCE RECORD - Copy.pdf
  • SERVICE INTERVALS - Copy.pdf
