Kawasaki 2 cylinder oil drain is the pits!
overdriv
Does anyone know of a fix for the oil drain on my Kawasaki 21.5hp twin cylinder engine on my Cub Cadet mower.
As is it runs oil all over underneath the engine, very messy.
I took the drain out of the block and it is some metric straight thread. It actually seals on an o-ring just behind the threads.
I'd like to get it out passed the frame so I could catch the oil easier.
Hoping Kawasaki has made a longer drain to remedy this messy problem.
Thanks for any help.
go to a boating shop & get a sump pump.
Then you can forget about messy oil changes on everything forever.
Get a big one & you can use it on your vehicle as well.
7394
