I have a Kawasaki FH580V 19hp engine that bogs/backfires for a few seconds when I engage the mower deck. Sometimes after a few seconds it then revs to full speed and other times it just continues to back fire and run at a reduced speed. When its not underload it revs and runs ok. I've check the compression and both cylinders are over 100 psi, I've cleaned out the carb, replaced the fuel filter and spark plug and set the valve lash to 005. I've also check to make sure the blades on the deck aren't bent. Now of the above have cured the symptom. I believe the backfire is through the carb. I'm thking it could be the intake valve, but would I still be getting over 100 PSI compression if the vale wasn't seating? Or shoudl I be looking somewhere else for the problem.
