johndeere d120
mr.wrench
john deere d120 wont start I replaced starter-starter solenoid-battery could any body tell me how many switchs are in d120
it s4eem when I wiggle or fool around with any switch it willstart sometimes I need help bad thank you I put a tune on it thank you
Mikel1
I have a d110
I would check for a loose wire/connection since you can wiggle wires and it start. Could also be a problem with a switch.
I wish you would have come here before blindly replacing parts but whats done is done.
mr.wrench
I have a d110
I appreciate your help im to point I just don't know what to do thank you
bakerg
This is what John Deere says in trouble shooting part of the manual if it will not start.
Brake pedal is not depressed.
Mower is engaged.
Battery terminals are corroded.
Battery not charged.
Blown fuse.
Fusible Link in starting circuit is blown - See your authorized dealer
So based on this and what you have said about it sometime starts if you wiggle the wiring, I would say check the mower engage switch and the brake pedal switch.
Start at the solenoid and follow the wires back
JD is fairly consistent with their wiring colours .
So any switch with 4 wires the black or white ones are for the magneto cut out.
The other coloured ones are the engine cranking switches.
In general they go
Solenoid - reverse -brake - PTO - Key - Battery
