Engine John Deere
Ironhawk
I have a C116L Reading lawnMower. and i would like to know if i can convert from Eletric start to pull start
You don't tell us what engine you have on it, so it is hard to answer.
Kohler, Briggs, Kawasaki??? Also need the engine numbers.
Ironhawk
Ok here it is. It is a Briggs @Straition. M#402707--type-01310----code-82022212. I hope this help
You cannot put a recoil starter on this engine. If you can find the parts (this engine was built in 1982) you could put on a warp around cup. This web sit might help you with the part numbers you would need.
Jacks Small Engine Parts Help Page
A wrap around cup is what we call a starter cup where you warp the cord around the cup and then pull to start the engine. If you take a look at the website you will see it.
