Hello all,
I have a JD X380 with only 34 hours on it. It suddenly began sputtering, backfires a few times and stops. It won't start back up immediately, but will within a few minutes. It does the same with or without the blades engaged. It worked perfectly up to this point. I considered a possible bad fuel problem, but the first part of the gas from the can seemed fine. Any help would be appreciated. Thanks.
#2
dfbroxy
Since I think this machine may still be under warrenty I will advise only to drain and clean fuel tank. Also change fuel filter. If this doesnt help let us know.
