John Deere X320
Dorsett42
I have a John Deere X320 with a Kawasaki engine and 42 in mower deck. It will start and run with the choke engaged but will not continue to run when the choke is released. It has a new fuel filter and gas line and the fuel pump appears to be working. Any suggestions?
Dorsett42
Mikel1
Welcome to the Forum!
If you have good fuel flow to the carb then the carb needs cleaning. If you have to use choke to keep running then there is a restriction.
Briana
Welcome to LawnWorld!
We moved your thread to the John Deere forum.
